on 14-04-2025 09:05 PM
My router keep dropping certain devices not letting them reconnect. It does it multiple times in a day - usually sky box, my printer & car charger. Switching router off and on sorts it out but I have to do this multiple times a day. A factory reset of the router seemed to fix the problem for a week but then it happened again.
Online technical chat is useless - they either want to sell me a signal booster or upgrade my service to get a better router.
I don't believe it is a wifi signal issue - if it was why would devices connect back up as soon as router is switched back on ?. Printer is only a couple of metres from router so I certainly gets a good signal.
Lots of other posts have a similar problem and they got new router which appears to fix the problem but nobody I chatted to was prepared to provide a new router.
on 30-04-2025 09:46 AM
I'm glad to hear you've managed to get a new router! Here are some tips to try if you experience any dropouts:
If these steps don't resolve the issue, it may be due to stability or equipment problems. In that case, we recommend contacting our Tech Support Team using the information provided below.
Call: 03451720074
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
Chat link : How to contact TalkTalk Broadband
WEB MESSAGING - Mon-Fri: 8am-9pm; Sat: 8am-7pm; Sun: 9am-7pm
Kanya
on 29-04-2025 08:51 AM
Thanks for the new Router. It's been stable since installed with no dropouts.
Before I swapped routers I used a wifi signal app to see what was happening. When the old router dropped 3 devices it was not broadcasting any 2.4g signal. Other devices continued to work as they were either hardwired into the router or were on 6g signal.
I went into router settings and router was not reporting any issues.
Could this be caused by something interfering with the signal ?.
I only ask this incase it happens again with the new router.
on 15-04-2025 07:25 AM
I have ordered you a replacement router, please allow 24-48hrs for this to arrive.
Let us know how the connection compares with the new router.
