Eeros pro 6 wont update
Will2410
Message 4 of 4
My eeros shows an update available but won't update no matter what I do
3 REPLIES 3
Message 1 of 4
Whilst an update may be showing it may not update to schedule immediately. Eeros are updated in batches so it may be a couple of days before yours auto updates.
I find that trying to update manually does not work first, second or even third time! I find force stopping the app seems to clear it and it will then update.
I used to be paranoid about having the latest update but now just let it be as @ferguson says it will auto update and I dont see any difference in connection etc. once it's done.
Will2410
Message 2 of 4
I was kind of hoping that would be the case,my auto update is set for 2am. hopefully it will update itself correctly I will check again tomorrow thanks
Message 3 of 4
You don't need to do anything, it will take care of itself.
