on 23-03-2025 10:19 PM
Since Saturday daytime internet keeps dropping out. Reconnects for a few seconds, then goes off again.
Ran a test and says there's no problem.
Connected to test socket and it's the same.
on 04-04-2025 07:06 AM
Please can you create a new topic on the Community, we can then take a look at this for you.
on 03-04-2025 09:29 PM
If you would like help from the support team then please start your own topic.
on 03-04-2025 09:02 PM
I am having the same issue, this has been ongoing since December 2024 when I upgraded to fibre. I am sick of complaining about it, they keep telling me the issue is resolved but it never is. I am now looking at different providers
on 31-03-2025 08:54 AM
Hi edboy104,
I'm glad to hear that the engineer has resolved the issue, if you do experience any further problems please let us know
on 27-03-2025 03:50 PM
OK, I don't know what all that means.
All I know is what I have previously written regarding what the Engineer said to my wife.
on 27-03-2025 01:35 PM
Hi edboy104
The engineers notes are below:
Engineer has resolved the fault located at the D-side including aerial cables / lead-in / block terminal. There was a fault outside the end customer's curtilage caused by general wear and tear. The fault was fixed by changing the pair in cable length.
on 27-03-2025 12:02 PM
No. Different landline number.
Separate, Independent cabling.
I wasn't here to ask questions of the Engineer.
Do Talktalk not get a report or feedback from Openreach?
on 27-03-2025 11:38 AM
on 27-03-2025 11:36 AM
Yes, 2 separate lines; one to main house, the other to annex (unoccupied).
Talktalk contract is for main house.
The problem was wiring that feeds to main house.
No live contract with annex.
Eng switched the cabling from the annex to the main house.
This is my understanding of their fix.
I was not present when it was done.
I have had no report or follow up directly from Openreach.
on 27-03-2025 10:40 AM
Hi @edboy104
Just to confirm, you have 2 separate lines at the property and now the 2nd connection/line is not working?
on 27-03-2025 10:34 AM
So, broadband connection is now ok after Openreach Eng visited. We were out, initially, but he found the problem was related to wiring inbetween trees further up the Lane. He wasn't able to resolve this on his own.
However, we have an annex with independent cabling. He switched that cabling over to us as there is nobody living in the annex.
So we are connected, but the original problem is still there which he told my wife we would have to log as a new call out when we need both connections to be live.
on 27-03-2025 07:46 AM
on 26-03-2025 07:35 AM
Hi @edboy104
Openreach have closed the fault as resolved. Please can you let me know how the connection is over the next 24hrs?
on 25-03-2025 10:29 AM
Morning @edboy104
This fault is still with the Openreach line engineers, there are no additional updates at the moment.
I will keep checking for updates.
on 24-03-2025 10:17 AM
on 24-03-2025 10:04 AM
OK, thanks.
on 24-03-2025 10:00 AM
Hi @edboy104
Thanks for confirming this.
I have passed this fault straight over to Openreach to be investigated by a line engineer (external investigation)
I will post back here as soon as I have further updates.
on 24-03-2025 09:47 AM
Yes, the router is still connected to the test socket.
24-03-2025 09:41 AM - edited 24-03-2025 09:49 AM
The router is still connected to the test socket.
on 24-03-2025 09:29 AM
Hi @edboy104
I've completed a line test and this is detecting a potential fault.
Is the router still at the test socket at the moment?
