Wifi settings keep changing
on 18-10-2022 01:01 PM
Message 11 of 11
Hi, I've been having trouble with devices dropping off the wifi regularly over the past 2 weeks or so.
I've found that the settings on the Wifi page - e.g. Channel Selection & bandwidth keep changing away from what I choose. They revert to Channel 36 & 80MHz which is causing me big issues.
Is this a fault with the modem ? It's a FAST5364 3.00 & I think it's software may have updated recently to SG4K100136.
Thanks,
Aidan
Labels:
- Labels:
Wifi
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
10 REPLIES 10
on 21-10-2022 07:51 AM
Message 1 of 11
Hi aidangardham,
Glad to hear it's been OK. I think for the vast majority of people it works fine and improves wifi connectivity but it some cases it doesn't seem to work as well unfortunately.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 21-10-2022 07:41 AM
Message 2 of 11
After 3 days, I've not had a single issue since switching off the Wifi optimisation.
For the record, it was the bandwidth setting (in Wifi 5GHz / Advanced) which did it & the optimisation did stop that from reverting.
So I can join what must be a large number of people that officially hate Wifi Optimisation & consider it a bug, not a feature.
Thanks again for your quick help Chris.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-10-2022 01:22 PM
Message 3 of 11
No problem 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-10-2022 01:20 PM
Message 4 of 11
Thanks Chris.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-10-2022 01:18 PM
Message 5 of 11
OK, it's disabled now. You can now manually change channels
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-10-2022 01:12 PM
Message 6 of 11
It's not that new, it's been around a while. I'll disable it now and get back to you when it's done
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-10-2022 01:10 PM
Message 7 of 11
Yes please Chris.
Is it a new feature ?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-10-2022 01:09 PM
Message 8 of 11
Wifi optimisation automatically changes to the best channel but if you are experiencing problem we can disable it for you. You can then manually set your own channel. Would you like me to disable it?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-10-2022 01:06 PM
Message 9 of 11
Hi. I haven't heard of Wifi optimisation before, does it override the settings on the webpage ?
Will it keep the bandwidth setting stable as well ?
If so, it sounds like I need it disabling. How do I do that ?
Aidan
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-10-2022 01:04 PM
Message 10 of 11
Hi Aidan,
We could try disabling wifi optimisation, this will stop the router automatically changing channels and will allow you to set your own channel. Do you want to give this a try?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
