how to add an ip address into a wireless device
alfvon1
Message 2 of 2
1 REPLY 1
Message 1 of 2
Please can you elaborate on what you want to know? By default, any wireless device is allocated its IP address automatically upon a successful connection to a wireless network, via the DHCP server. This is typically located in the router of a domestic installation.
