on 07-04-2024 12:35 PM
I'm only getting 4mb at best, Others offering 10 x this.
you offer minimum of 11mb on your adverts,
done the tests 7 you say everything is fine but it is slow,
on 09-04-2024 09:33 AM
Hi @Carlaclark
Do you still need help with this?
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
on 08-04-2024 07:16 AM
Hi Carlaclark
on 07-04-2024 01:26 PM
2. What package are you on?
3. If you log into the router, what speeds does that detect?
4. If you have any wired connections, are they affected in the same way as wireless ones?
5. Which WiFi band are your slow devices connected to, the 2.4 or 5GHz bands, perhaps a mixture of the two?
