on 02-04-2023 07:46 PM
Hello.
I have a contract for a Fiber35 package. The download speed is about 27 Mbps and the upload speed is about 6 Mbps. On February 23, the speed suddenly dropped to about 13 Mbps to the router and 11 Mbps to the PC. A line check showed a problem. On March 2, an engineer arrived. After his visit, the speeds did not change much and the line test continued to show the problem. After about three weeks, the line test shows that everything is fine, but the speeds to the router are 18 Mbps and to the computer 15 to 16 Mbps. This situation continues to this day. I don't understand why the speeds can't go back to normal as they were according to the subscription, and it's been over a month! My neighbor has Internet on the same network and still has normal speeds and we are connected the same way!! I do not understand! I'm still using the original router and cables I received when I first connected, and why is the speed difference 2 to 3 Mbps? Please explain this problem to me and help me get back to normal.
on 14-11-2024 06:56 AM
I'm glad to hear that this has been fixed and speeds have improved.
Monitor and report back here should they drop again.
on 13-11-2024 03:58 PM
on 12-11-2024 12:17 PM
I've booked the appointment for - November 13 2024, PM - please let us know how you get on
on 12-11-2024 12:11 PM
Thanks. I'll book the engineer now and get back to you with the details
on 12-11-2024 11:54 AM
Hi Chris
Ok. I have no other choice but to accept these conditions.
Last time I accepted these conditions, despite the engineer's different assessment, I was still charged a fee.
I can't understand one thing - the same thing repeats itself in a cycle of about a month - where is the problem that it can't be fixed once and properly?
After the line test, information about a problem on the line, I don't have to be at home and then very quickly information that I have to order an engineer, etc. This is really tiring.
Please order an engineer for Wednesday or Thursday between 1 and 6 pm.
Les
on 12-11-2024 07:10 AM
OK thanks Les, if you'd like me to book the engineer can you confirm:
on 11-11-2024 03:11 PM
No. The signal sound is clear.
Les
on 11-11-2024 02:58 PM
OK thanks. Line test is passing but showing some disconnections. Are you currently experiencing any problems with your telephone service, any noise on the line?
on 11-11-2024 08:53 AM
Thanks for your help.
Unfortunately, the speed is still at 12 to 17 Mbps.
Best regards
Les
on 11-11-2024 07:10 AM
Hi Les,
Yes we can book an engineer for you. Has anything changed over the weekend or is the speed still low?
on 08-11-2024 08:31 PM
Hi Chris
For over a week the speed has dropped from 30 Mbps to about 18 - 22 Mbps, to drop to about 7 Mbps yesterday. I ran a line test and received information that there was a problem on the line. Today I received information that I should order an engineer. This is where the problem occurred, because the links to order an engineer do not work and I cannot do it and I only have 48 hours to do it. Can you help me order an engineer? Case number - REP-14950284. On Monday and Tuesday after 2 pm I am at home.
Thank you for your help.
Best regards
Les
on 14-10-2024 02:07 PM
The line check should clear when this fault is closed
on 14-10-2024 01:44 PM
Thank you for the information.
Were you able to complete the July 9th report and unblock the line check function from my account?
Les
on 14-10-2024 12:25 PM
Hi Les,
Line test is failing so I've passed this back to Openreach for investigation. Openreach will investigate over the next 72 hours and may contact you directly if they need to access your home
on 13-10-2024 07:27 PM
on 26-09-2024 07:28 AM
OK thanks Les 🙂
on 25-09-2024 04:49 PM
Ok. No problem, I can use it.
It was replaced quite a while ago when the internet problem occurred again.
I will work on it and see what happens.
Les
on 25-09-2024 02:02 PM
OK thanks. The speed that the router syncs at really depends on the line profile and the background noise on the line. If the router is in sync at a high speed, an increase in noise on the line can cause the router to lose sync and resync at a lower speed due to the increased noise, it will then stay in sync at the lower speed until the router is rebooted. So I can understand why rebooting the router would increase the speed but I can't understand how rebooting the router doesn't increase the speed but swapping it for another router then swapping back to the original does result in a speed increase
Is there any reason why you can't just continue to use the older router if it doesn't have the same problem with speed dropping?
on 25-09-2024 01:50 PM
This has been done before and today. No effect.
Les
on 25-09-2024 01:36 PM
If you just switch the router off for 30 minutes rather than replacing it does this not restore the speed?
