on 02-04-2023 07:46 PM
Hello.
I have a contract for a Fiber35 package. The download speed is about 27 Mbps and the upload speed is about 6 Mbps. On February 23, the speed suddenly dropped to about 13 Mbps to the router and 11 Mbps to the PC. A line check showed a problem. On March 2, an engineer arrived. After his visit, the speeds did not change much and the line test continued to show the problem. After about three weeks, the line test shows that everything is fine, but the speeds to the router are 18 Mbps and to the computer 15 to 16 Mbps. This situation continues to this day. I don't understand why the speeds can't go back to normal as they were according to the subscription, and it's been over a month! My neighbor has Internet on the same network and still has normal speeds and we are connected the same way!! I do not understand! I'm still using the original router and cables I received when I first connected, and why is the speed difference 2 to 3 Mbps? Please explain this problem to me and help me get back to normal.
on 19-02-2024 02:21 PM
This cable is a longer version of the ADSL cable with two RJ11 plugs. I have been using this cable for about 10 years and have had no problems. Speeds reached up to 33 Mbps. I have currently ordered a new 7-meter cable. I need this cable length.
Les
on 19-02-2024 02:12 PM
Is the cable that you are using to connect the router to the test socket just a longer version of the ADSL cable provided with the router, or is it a telephone extension cable?
on 19-02-2024 11:02 AM
Hi Michelle
The router is constantly connected to the test socket through a filter. Yesterday evening I measured the speed - about 25 Mbps. I did a line test yesterday and received an error message on the line. I did not change the cable because the socket is at the entrance door and the router is on the first floor and the cable I received was too short.
Les
on 19-02-2024 07:47 AM
Hi Les,
Thanks for the update. I've re-run the line test now which has detected the same fault. Can I just confirm, did you also swap the cables and microfilter? Is the router also connected to the test socket at the moment please?
on 17-02-2024 12:51 PM
Hi Michelle
Today I received the router and filter. Thank you. Currently, the router is connected through a filter to the test socket. It will remain on until I receive information from you that the test is completed. After connecting, I measured the speed - about 30 Mbps.
Les
on 16-02-2024 02:02 PM
Hi Les,
The replacement router is on the way. Please let us know once this arrives and is connected to the test socket via the microfilter and we can re-run the line test again in this set up.
on 16-02-2024 01:41 PM
Ok. Please do what you think is necessary to finally fix it. My socket has a filter inside, I connect the cable without a filter directly to the socket.
Les
on 16-02-2024 01:26 PM
HI Les
The line test today did show a fault towards the property. I think we should send a new router and filter so this can be connected at the test socket,
We can then run another line test and this will also rule out the router and faceplate at the same time.
on 16-02-2024 01:23 PM
On February 12, I did a line test and a problem was found on the line. I still get a message about an open report and observation of the line, but nothing changes.
Les
on 16-02-2024 01:20 PM
There is such a socket - the engineer connects it when it arrives, but a different plug is needed than the one on my cable. I can only connect my cable to the socket for normal operation.
Les
on 16-02-2024 01:07 PM
Hi Les
Just to confirm, you can't connect to the test socket because you don't have one or because it's inaccessible?
on 16-02-2024 12:47 PM
on 16-02-2024 12:23 PM
Hi Les,
I'm sorry to hear this and I'll take a look now. I've re-run the line test which has detected a potential fault towards the property. Can I just confirm, is your router connected to the test socket please?
on 16-02-2024 12:07 PM
Hi Chris
Happiness doesn't last long. Since yesterday, the speed has dropped to about 19 Mbps, today the internet stops, the speed is still about 19 Mbps, turning the router off and on does not change anything - this method will probably not solve the actual problems. Will it finally end and when? This is already annoying. This situation has been going on since April last year. Please help me finally solve it.
Les
on 13-02-2024 01:55 PM
No problem 🙂
on 13-02-2024 01:20 PM
Understands. Thank you for your help.
Les
on 13-02-2024 01:15 PM
Hi Les,
Glad to hear that there's been a speed improvement. If the speed does drop again it's always worth switching the router off for 30 minutes as this forces the start of a new session and often results in faster speeds
on 13-02-2024 01:12 PM
After turning on the router, the speed increased to 30 Mbps. Thank you, very nice. Will it work like this all the time or should I repeat this operation in case of problems?
Les
on 13-02-2024 12:20 PM
Thanks. Could you switch the router off and leave it off for 30 minutes, then switch back on and check to see if the speed has improved
on 13-02-2024 12:16 PM
Hi Chris
The phone regained signal. Works. Internet speed remains unchanged - 19 Mbps.
Les
