on 13-05-2025 08:33 PM
Can anyone explain why my incoming messages have suddenly started arriving in my draft folder and better still tell me how to get them arriving in my inbox where they should be.
on 19-05-2025 05:17 PM
Hi there @Tansea, I am pleased to say that this has now been resolved for you, there was a rule on your emails which directed all your incoming mail into drafts, this has now been removed, and your emails will no longer go into your draft folder. Once again, I am really sorry that you've experienced this, thank you for contacting us and please reach out should you need anything else.
on 19-05-2025 04:12 PM
Apologies for that, Service Management Centre. Which is the department that'll look into this for you.
Apologies for that, Service Management Centre. Which is the department that'll ook into this for you.
on 19-05-2025 04:07 PM
I am grateful for your action but out of curiosity can you tell me who SMC are?
on 19-05-2025 03:21 PM
Hi there @Tansea. We have escalated this issue regarding your emails going to your draft to SMC and when we have an update we will post it for you. Thanks
14-05-2025 03:41 PM - edited 14-05-2025 04:52 PM
All had been well before my email address was subject to a major hacking event whereby all my contacts received a series of scam emails from an unknown source using my address.. I involved the TalkTalk team and during the following process all my folders were emptied out including my inbox. My inbox was therefore empty and since then all my incoming mails have arrived in my draft folder. I have not received any conclusion from TalkTalk in regard to the hacking problem and the only positive action taken is that I have changed my password.
on 14-05-2025 10:28 AM
@Tansea, could you double check if your Inbox mail space is full or not as this normally occurs should there be not enough space. Meaning so, if your Inbox folder is full, other incoming mails will be re-directed to other folders such as Spam or draft.
on 14-05-2025 10:18 AM
It is the same
on 14-05-2025 09:31 AM
Okay can you please use webmail for me and tell me if this issue still continues.
on 14-05-2025 09:28 AM
Via the blue mail app on my iPad.
on 14-05-2025 09:13 AM
Okay thank you for confirming, how are you accessing your emails?
on 14-05-2025 09:07 AM
Hello Angelique, thanks for replying. I am referring tom my tiscali.co.uk messages.
on 14-05-2025 08:20 AM
Good morning Tansea. Please confirm if you are referring to your emails?
