Amazon eero Router.
Tonysheff1
Message 4 of 4
Do I have to instal this Router when I get it or can I still use the one I have now.
3 REPLIES 3
Message 1 of 4
Hi Tony,
Please let us know if you need any further assistance,
Divsec
Message 2 of 4
Hi @Tonysheff1 if what you have works well and does what you need why bother changing.
You will have a spare ready to go should the existing fail.
Don't forget the Eero is locked to talktalk and should you ever decide to switch isp it will likely be requested for return.
Message 3 of 4
It kind of depends. Which Full Fibre service have you upgraded to and do you have VoIP included? Which current router do you have?
