Blocked website
AlastairMutch
Message 25 of 25
TalkTalk has suddently started blocking web access to a number of websites that I use daily. These are all on the same server / IP address. 5.77.55.132
How do I get this block removed and normal service restored.
The sites are:
https://www.scottishgliding.com
and a number of other sites on the same server.
I can access them OK via another internet provider.
I have turned off all the security tools for TalkTalk.
Alastair
24 REPLIES 24
Message 21 of 25
Yes I rebooted the TT router before posting on here.
Alastair
Message 22 of 25
Sorry to state the obvious but did you try rebooting your router?
Message 23 of 25
Interesting. Perhaps an Edinburgh problem then.
Yes I tried two different computers using Chrome, Firefox and Edge. Same results on all of them.  Email is also blocked as is file replication for our cloud filestore. All ports seem to be blocked, not just http 80 and https 443.
I haven't found any other sites being blocked.
If I connect either computer via my mobile phone hotspot the sites work perfectly.
If I connect the computer via a remote proxy the sites work perfectly.
So it appears to be a TalkTalk routing / blocking problem that just started but may be a fault with a bit of local kit.
Alastair
Divsec
Message 24 of 25
Hi @AlastairMutch sad to say I cannot replicate and can access from chrome on Android.
Have you tried clearing your browser cache and even a different browser?
