Broad band down in ws7
Tomcat13
Chat Champion
Message 108 of 108
Any one else in ws7 with no broadband
T Taylor
107 REPLIES 107
Message 21 of 108
A factory reset is required on your router which will restore the router to it's original settings, including the Wi-Fi Network name (SSID) and password.
If the password has been changed, please refer to the one on the stickers attached to your router to find the original password.
Once the No Internet connection issue is resolved, I can assist you in reconnecting to the network.
Message 22 of 108
No I haven’t done anything. It was working fine until 12.30 on Monday then it just went off. How can I tell if the WiFi name or password has been changed
T Taylor
Message 23 of 108
Have you made changes with the WiFi Network name (SSID) or password?
Message 24 of 108
It’s still on a solid orange light and no service
T Taylor
Message 25 of 108
The router has successfully connected to the Internet after the reboot.
We can now continue to work with you to investigate the issue you've reported to us.
Message 26 of 108
An automated check is in progress to check if the router is able to connect to the Openreach street cabinet. This can take up to 3 minutes to complete. I'll let you know once it's finished.
Message 27 of 108
It’s just on solid orange light and no service
T Taylor
Message 28 of 108
As a change has been made the router will need to reconnect - this can take up to 6 minutes. If it connects sooner, then we'll be able to progress once we see it connect.
Message 29 of 108
As a change has been made the router will need to reconnect - this can take up to 6 minutes. If it connects sooner then we'll be able to progress once we see it connect.
Message 30 of 108
Now it’s back to solid orange and no service
T Taylor
Message 31 of 108
It is attempting to connect, but I am still running checks on my end.
Message 32 of 108
It’s now flashing orange and white
T Taylor
Message 33 of 108
Thank you for confirming.
Message 34 of 108
I’ve done all this. Including doing a factory reset and removing the cover from the wall box and plugging into the test socket. Nothing works. Maybe it’s the router or the filter that needs replacing. I’ve just switched it off and back on. It’s just flashing orange.
T Taylor
Message 35 of 108
Please restart your router by either pressing the power button on the side or switching it off at the wall socket. Wait 10 seconds to ensure it fully powers down, then turn it back on. Let us know when you are done, thanks.
Message 36 of 108
A line test has not identified an issue outside your premises. As you've not made any changes before this issue started, the next step is to look at the router.
I'll guide you through the router checks - ensuring it's up to date and addressing any potential temporary issues that could have caused the disconnection from the Internet.
If these steps don't resolve the issue then I'll look at other potential causes
Message 37 of 108
No. It was working fine up to 12.30pm on mon then just went off
T Taylor
Message 38 of 108
Have there been any recent changes in your home that could have impacted your service?
For example - new or replacement equipment, building work on the premises or damage to any wiring in or around the home?
Phili
Message 39 of 108
No
T Taylor
Message 40 of 108
Are you currently using an Openreach Modem in your setup?
This is a a white device with several lights, which may be connected to your master socket. Typically it will have an openreach sticker on it.
Phili
