Broadband connection dropping
akoumi
Chat Champion
Message 32 of 32
Hi support,
I have been experiencing my broadband dropping throughout the day over the last few weeks (since middle January 2024).
I have run a talktalk "run a healthcheck" from my TalkTalk MyAccount login and it came back as OK.
It has already occurred twice today at approx. 11:55hrs and 14:11hrs and the drop lasts for a very short time (approx. 1-5 secs).
I'd appreciate if you could please look into this and check the connection logs from your side, as this seems to be happening every day and been so for a good few weeks.
Thanks in advance.
Andy
31 REPLIES 31
Message 2 of 32
on it now 😃
Cheers
Message 3 of 32
Hi Andy
I'm so glad to hear this 🙂
If you do experience any further issues then please let us know.
I've sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 4 of 32
Good Morning Debbie,
The connection has been fine since you disabled WiFi Optimisation and I'm therefore happy for this support request to be closed down.
Thanks for all your and the wider team's help (e.g. @KeithFrench) on getting this issue resolved.
Happy Friday!!
Cheers,
Andy
Message 5 of 32
Good morning and Happy Friday 🙂
How's the connection been this week?
Message 6 of 32
Message 7 of 32
Thanks Debbie, your support is greatly appreciated!!
Message 8 of 32
Hi akoumi
That's great news.
Of course that is no problem 🙂
I will check in again with you next Friday. Have a good weekend 🙂
Message 9 of 32
Hi Debbie,
The WiFi has been stable and had no drops since you disabled the WiFi Optimisation. I'd like to monitor for one more week if possible before closing down this support request if that's OK? Or if you'd prefer to close this one down and me raise another request if required?
It's looking good at the moment!!
Message 10 of 32
Hi akoumi
How are you getting on, how's the connection been?
Message 11 of 32
Message 12 of 32
Thank again, I'll update you in a weeks time. 👍
Message 13 of 32
Hi akoumi
Thank you. WIFI optimisation monitors the connection and will try and choose the best wireless channel for you.
Sometimes customers prefer to choose their own wireless channels.
Message 14 of 32
Thanks Debbie,
I'll monitor the WIFI connections over the next week and let you know how I get on and whether you should turn the WIFI Optimisation back on.
Just out of interested what does the WIFI Optimisation do and will it affect the download/upload speeds with it turned off?
Thanks,
A
Message 15 of 32
Hi akoumi
I've switched the WIFI optimisation off.
Message 16 of 32
OK thanks for the explanation and i have not requested that WiFi optimisation be disabled in the past, so it's probably still enabled.
@Karl-TalkTalk  is this something you can help with please?
Message 17 of 32
It will be enabled by default unless you request TalkTalk disable it for you, which I would recommend to start with. It can easily be re-enabled at a later date. Just request that they disable it for you (it has the power to change any of your WiFi configuration at will) in your reply. Then we'll see what happens.
Message 18 of 32
Not sure, how can i check?
Message 19 of 32
Yes, I can now see the issue, you are being kicked off as the security settings have been saved. I have seen this before but have never been able to get to the bottom of it. I have never seen this on my router. Do you have WiFi optimisation enabled?
Message 20 of 32
Hi Keith,
We encountered another drop earlier today at 13:16hrs, and as Franco recommended below I have collected the "Info & lower" logs for that time period for you to look at.
Please see attached logs.
Andy
