Cannot connect to eero 5ghz network
Paul19641964
Message 8 of 8
5ghz capable devices will not connect to eero 5ghz network.
Android phone, that always did connect to eero at 5ghz, now only connects at 2.4ghz. Laptop that mostly connected at 5ghz, will now only connect at 2.4ghz. Could this be due to the latest of the frequent eero firmware updates? Please can I have a regular (non mesh) router? Had no trouble with previous TT router.
7 REPLIES 7
Anonymous User
Message 1 of 8
Thanks ferguson
Message 2 of 8
@Sunflower5
I see you have started your own topic, please wait for further responses there.
Message 3 of 8
Hi I'm also coming across this problem with not being able to connect to 5Ghz recently.
2.4Ghz:
Channel and control channel both 11.
5Ghz:
Channel 155, Control channel 161.
What's the fix?
Daniel Jeyaraj
Anonymous User
Message 4 of 8
Thanks @KeithFrench
Message 5 of 8
The descision as to which WiFi band to connect to is solely down to the device. It accesses the signal quality (levels of signal strength or Wi-Fi interference). However, there is quite a common problem I have seen with the eero 6 (should not affect the eero Pro 6) is that the eero can use a 5GHz channel number that is too high for your devices. There is a patch for this. The first step is to check this out by using the eero app & going to:-
  1. Tap Home
  2. Tap the eero (if more than one) that your devices are trying to connect to.
  3. Tap Wi-Fi Radio Analytics
  4. Tap 5GHz at the top of the page.
  5. Scroll down to the bottom of the page where there is a box that contains the Channel and Control Channel.
Please let me know what they are set to.
Message 6 of 8
Hi @Anonymous
No problems, I will contact @Paul19641964 in an hour or two.
Anonymous User
Message 7 of 8
@KeithFrench - would you be able to offer any guidance on this?
Anonymous User
