Devices contstantly getting disconnected from WiFi
itiseuan
Message 3 of 3
I'm a pretty new TalkTalk customer and although the service is stable in general, the WiFi is useless. We only use it for our phones and amazon firestick, but we constantly have to turn wifi off and on again on our phones or restart the firestick because the WiFi has cut out.
angelique-TT
Message 1 of 3
Good morning itiseuan. Please confirm if you are still experiencing issues with your Wi-Fi?
Message 2 of 3
Hi @itiseuan
I can help a lot with this. What make/model of TalkTalk router are you using?
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
The information below is provided by TalkTalk. For confirmation, please contact @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
