Upgrading from Eero 6 to Eero pro 6
Newtopro6
Message 3 of 3
Hi just had delivery of Eero pro 6 instructions seem quite straight forward in leaflet. In reality just plug in and follow the striations on the app. Plugged in and powered on nothing happened on the app. I presume because this is a new device. Doing have delete the old device? Does this then allow you to add the new pro 6?  I wonder if anyone else has come across this problem.
Rob
Newtopro6
Message 1 of 3
Thanks Keith that worked a treat.
Message 2 of 3
I would delete the eero 6 first from your network. Connect the Pro 6 physically, then click the + icon in the app to add it.
