Eero 6 advanced security blocking sites
mrb1972
Message 4 of 4
Does anyone else have an issue with their Eero 6 blocking accesses to seemingly random websites, for example I have been blocked making a purchase on the official LG direct website, booking an appointment on a dental website, all pretty random ones.
If I disable the advanced security option in Eero Secure then they all work fine, but turning that off is not ideal - (I am using the latest firmware)
3 REPLIES 3
Message 1 of 4
Hi mrb1972,
Do you get an error/notification message when the pages are blocked?
mrb1972
Message 2 of 4
Yes, I have read all that, it makes no difference, it used to be fine then just recently started blocking stuff for now reason, the only fix is to disable Eero Secure from the app.
*** I have posted this in the wrong forum - apologies ***
Message 3 of 4
Have you had a look at the below Help Guide?
Managing your eero secure content filters - TalkTalk Help & Support
