on 02-03-2023 10:54 PM
Today I suddenly had several devices fall off the wifi network, they would state there was no internet on the wifi connection and turning them all on and off again did not solve it.
I therefore did a quick powercycle of the router, made no difference, in fact some of the ethernet wired devices then lost connection.
Did a 30 minute power down, no difference.
Did a factory reset through the routers web interface, connected devices via wifi, still no internet even though the light on the router was solid white. Power cycled again, no better.
Reset again, loaded old previously saved settings, no connections still
Pressed the reset button on the back, made no difference except the led now flashes orange and white and I can't connect to it either wifi or wired.
I had an old HG633 , connected that back up, all works at the moment.
This proves all cabling etc is fine but the FAST router is now dead, I suspect something expired inside earlier that caused wired devices to connect but only some wifi devices could connect, then all wifi lost connect and finally its a brick.
How do I go about requesting a replacement for the FAST router as I believe it is supposed to be much better that the old HG633 I have had to resort to?
on 07-03-2023 06:42 AM
Hi Dave
I'm so glad to hear this 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
on 06-03-2023 06:37 PM
Hi Debbie
Router received and configured and working perfectly
Thanks for your help
Dave
on 06-03-2023 01:25 PM
Hi davy9111
on 03-03-2023 08:43 AM
Hi davy9111
No problem 🙂
on 03-03-2023 08:40 AM
Thank you Debbie 😉
on 03-03-2023 06:38 AM
Hi davy9111
I've ordered a replacement router, please allow 24-48hrs for this to arrive.
on 02-03-2023 11:01 PM
Nice one. I am confident from what you have said that they will arrange a replacement Hub for you.
on 02-03-2023 11:00 PM
Thanks, phone number added 🙂
on 02-03-2023 10:58 PM
If you would like the support team to look into this for you make sure that your personal details including TalkTalk phone number and/or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
