on 18-02-2023 03:58 PM
full fibre installed by enginners on 6.2.23. Eero router sent by talktalk beforehand. Tried countless times to set up using eero app. The router bluetooth connects to my phone, then tries to connect to the internet. It fails every time, saying on the troubleshooting page: NO EXTERNAL IP address detected. I've spent at least 5 hours now on the phone to technical help, who have all run very tedious and slow protocols to try and deduce the problem, whilst logging the case with City Fibre. Although all of the four lights of the full fibre connection box are green, even connecting an ethernet cable directly from the fibre connection box to a computer, the computer cannot detect the internet. I am now waiting almost a week to hear back from cityfibre about sending an engineer out. No text or contact whatsoever. Spoke to cityfibre, will not help at all "Discuss with your internet provider who can discuss it with us". Rang talktalk again yesterday, went through the same lengthy diagnostics process taking 75 minutes and no further forward, except they said they would emphasise to cityfibre that I wished to hear from them ASAP. It is difficult to know that anything is actually being done to investigate the fault from the cityfibre end, when I have to spend an hour on the phone each time to talktalk to find that nothing has been done!!
Has anyone had the same experience? Any obvious quick fixes? I have tried a hard reset of the eero device, as well as a reboot of the fibre connection box, as well as using the eero app on 3 separate phones (using amazon login- could this be the issue??) to initiate the connection but the same error occurs when the eero is trying to find the IP address. Argh!! I just need a cityfibre engineer to come out and test the connection. Clearly something has not been switched on or connected properly during the fibre installation.
Plus, talktalk accounts obviously thinks everything is fine, as I have already been billed (albeit the 3 month free introductory offer) from the installation date of 6.2.23 when it is still not working 2 weeks later!
on 06-03-2023 10:44 AM
OK, I've made a change that will hopefully resolve the problem. The change will take effect with 24 hours but it doesn't usually take that long
on 06-03-2023 10:11 AM
Hi Jim,
I think I can see the problem, just trying to find out how to fix it. Leave it with me and I'll get back to you
on 03-03-2023 11:14 PM
OK, it was just a thought. The support team won't be back online until Monday, hopefully they can advise further then.
on 03-03-2023 11:05 PM
I'm using the ethernet cable that came with the eero 6 pro router. I assume as I purchased a 500 MB/S full fibre contract it would be able to supply that? Just tried powering everything down for 30 mins as suggested and it has made no difference see talktalk speed rest, when device connected to the eero pro 6 router that is directly attached to full fibre connection box. Any suggestions, talktalk?
on 03-03-2023 10:58 PM
I meant 1Gbps, as opposed to lower which will only support up to to 100Mbps, sorry!
on 03-03-2023 10:34 PM
Wow, so Cat5e will work at 100Gbps, I learn something new!
on 03-03-2023 10:33 PM
Are you using a Cat5e Ethernet cable, preferably better? Otherwise it will be limited to 100GB.
on 03-03-2023 10:16 PM
I've tried it on multiple devices via wireless, connected to the Eero pro 6 router and it is stuck at 100 MB/S. I've just tried it using a computer connected directly to the fibre connection box with an ethernet cable and the max speed is exactly the same. I will try powering both off for 30 mins and let you know if any improvement. This is 'off peak' Tim ie 10pm on a Friday night.
on 27-02-2023 07:28 AM
Thanks for the update. Are you running the speed test wired or wireless? Have you tried powering down the ONT and the eero for a full 30 minutes and then tested the speed again?
on 24-02-2023 05:12 PM
Thanks Chris. It has now connected as of today, whixh is good. Connection speed doesn't seem right - download/upload seems stuck on 108 MB per second when it should be 500?
Any thoughts? I did a connection and line test on My Account and it seems to think there is still a problem?
on 24-02-2023 07:18 AM
Morning Jim,
How are you getting on, is everything OK now?
on 22-02-2023 01:59 PM
OK thanks 🙂
on 22-02-2023 01:50 PM
Many thanks Chris, will check tomorrow.
22-02-2023 01:03 PM - edited 06-03-2023 08:04 AM
Hi Jim,
I can see that you now have an internet connection so hopefully everything is OK now. Please let us know if you need any further assistance
on 22-02-2023 07:39 AM
Hi Jim,
How are you getting on, City Fibre have carried out work to resolve the issue, is your service now working?
on 21-02-2023 03:00 PM
Quick update, they think they've found the problem, just waiting for the engineer to get back to me
on 21-02-2023 02:46 PM
Thanks Jim, I'm currently chatting with a CF engineer about this, I'll let you know when I have an update
on 21-02-2023 02:45 PM
All 4 are green
on 21-02-2023 01:54 PM
Thanks for that, could you just tell me which lights are currently on on the ONT
on 21-02-2023 10:23 AM
OK thanks. I've sent you a PM to confirm some details so that we can look into this further
