Fast5364 Repeated dropped connection
TTFibreuser
Message 3 of 3
Afternoon.  I've been having problems, for weeks, with repeated dropped connections to the internet, at all times of day and night. It happens most frequently on the 2.4GHz band but also occurs on the 5GHz.  Often if the 2.4GHz drops, the 5GHz will retain access to the internet but few of my devices can run on the 5GHz band (my mobile uses both, which is how I've tested this).   I have a Fast5364 modem and have tried switching channels to avoid interference but there is no noticeable change.  A line test showed no issue, so I suspect a faulty router.  Can you advise please?
Message 1 of 3
Hi TTFibreuser
I can see that @KeithFrench has offered to help. Keith provides really great advice on improving wireless performance.
Do you still need help with this?
Message 2 of 3
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
