Flashing amber light on router
JC-74!
Message 18 of 18
Over the past few days my internet has been cutting out - a flashing amber light on the router. I have restarted it several times but that hasn’t helped. I spent 2 hours online with a TalkTalk advisor who told me that they had updated the Firmware on the router and that this would solve the problem. However, it hasn’t - the internet connection now cuts out every few minutes.
The router is several years old - do I simply need a replacement?
17 REPLIES 17
Message 1 of 18
Hi JC-74!
I'm so glad to hear this, thanks for letting me know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
JC-74!
Message 2 of 18
Yes, I’ve installed the new router and everything is now working fine.
Thank you for your assistance.
Message 3 of 18
Message 4 of 18
Hi JC-74!
You can connect your current router to your usual set up now.
Thanks again.
JC-74!
Message 5 of 18
Yes, that would be fine. Do you know when the router will arrive? And can I now remove the router from the test socket?
Anonymous User
Message 6 of 18
Hi again,
Great thank you. I've re-run the line test again now which is still detecting the same fault towards the property. Would it be ok if we send a replacement router for testing purposes first as the next step would be to arrange an engineer visit to the property?
JC-74!
Message 7 of 18
I have now attached the router to the test socket. How long do I need to leave it like this?
Anonymous User
Message 8 of 18
Would it be possible to connect the router at the test socket so we can re-run the line test again to see if the same fault is present please?
JC-74!
Message 9 of 18
The router is continuing to cut out occasionally, mainly during the evenings, and phone calls have also occasionally cut out. I reported this over a week ago and we’re no further forward. Are you able to tell me what action is being taken to sort this out?
Many thanks.
Message 10 of 18
Hi JC-72,
How has it been since your last post?
Are you experiencing any problems with your telephone service, any noise on the line?
JC-74!
Message 11 of 18
Yes, I do have a test socket. However, the router only cuts out very sporadically at the moment so I’m not sure whether the teats socket would identify the issue?
Could it be that the router is just old?
Message 12 of 18
HI JC-74!
This help page provides some more information on test socket testing.
Your guide to main phone sockets
Alternatively, if you post a photo of your master socket on this thread then I can take a look at this for you.
JC-74!
Message 13 of 18
Thanks for getting back to me. I’m not sure what you mean by a main and test socket - are you able to clarify what you mean? Have you any idea as to the type of fault we’re talking about?
Anonymous User
Message 14 of 18
I'm sorry to hear this. I've run a test on the line now which has detected a potential fault towards the property. Does your main socket have a test socket please?
Message 15 of 18
Tonight we had 2 hours of the following:
2 minutes of the router on - white light
2 minutes of flashing amber light
2 minutes of flashing amber and white
Continuously for the last 2 hours. Is this because TalkTalk were doing something remotely or just a coincidence?
it would be nice to be given an update about what, if anything, is happening.
Chris-TalkTalk
Message 16 of 18
Hi JC-74!,
If you still need assistance can you please add your TalkTalk home telephone number or account number to your community profile and we'll be happy to look into it for you
Message 17 of 18
Anonymous User
