on 14-04-2025 03:30 PM
I am thinking of upgrading to fill fibre. At the moment my router is in the front room. My landline is in the kitchen and a second handset with an answer machine is in the bedroom upstairs. Can I continue with this arrangement with full fibre? If so , how?
25-04-2025 01:43 PM - edited 25-04-2025 01:43 PM
@KeithFrench, Talktalk does provide them, but it sounds as though these just go with the Hub2, so that would limit your ambitions for speed a bit, @Weevie.
https://community.talktalk.co.uk/t5/Articles/Battery-Backup-Unit/ta-p/2815438
We have mentioned this in one of your earlier threads in recent months.
It's better if you follow up there as you have rather hijacked someone else's thread.
on 25-04-2025 01:37 PM
Ofcom set the rules - which must be adhered to......
on 25-04-2025 01:23 PM
When I upgraded, I was just told to keep a charged-up mobile handy, no battery backup at all.
25-04-2025 01:21 PM - edited 25-04-2025 01:24 PM
The UPS/Backup supply would be ones supplied by TalkTalk - To allow the continued use of an emergency phone, during any power blackout - for disabled customers.
I have no idea which router I would be supplied with.....
Access to emergency services in a power cut
Any provider of a voice communications service must make sure that customers have uninterrupted access to emergency organisations. For more detail, see General Condition A3.2(b).
Ofcom has published guidance on how we expect providers to meet this requirement when there is a power cut. The guidance has four main principles, namely that providers should:
Providers should offer this solution free-of-charge to customers who depend on their landline to call emergency services during a power cut.
25-04-2025 01:00 PM - edited 25-04-2025 01:01 PM
What router would you be getting. A Hub2 or 3 (both include Digital Voice) only needs one power point, plus the ONT needs power. Your cordless phone system will need one as well. If you have the eero, you can add one more to the list, as there will be the Grandstream ATA for Digital Voice.
Is this a UPS of your own, if so one for that & it depends on how many of the above devices it can power.
on 25-04-2025 11:27 AM
So how many power outlets do you need if you are getting voice installed along with full fibre and a UPS (battery back up) ?
on 14-04-2025 03:53 PM
Hi @Don9999
Yes. When you order Full Fibre make sure that you order it with Digital Voice.
This will (depending on the supplied router) either give you a separate box called a Grandstream DVA, which has a standard landline phone socket on it or a router with the landline phone socket built into it. Think of that as your new master socket. The easiest way to get what you want is to use an ordinary DECT cordless phone system with two handsets & an answering machine if required. Then just connect the basestation to the router's Phone socket rather than your current phone socket.
