Hosting a website locally - Restrictions?
jaffyjames
Message 4 of 4
I have a website and using Apache to create my own web server. I have it all configured with port forwarding, but cannot access it using my public IP address.
Can anyone tell me if there are restriction on hosting a website on your own machine and making it available through your IP?
3 REPLIES 3
Message 1 of 4
Thanks for your help @KeithFrench 🙂
jaffyjames
Message 2 of 4
Thanks Keith for you help ! I checked it on my mobile and it is working. Thanks again
Message 3 of 4
You will not be able to access it via your WAN IP address or DDNS domain from a device connected locally to your router. Any traffic going out from the router to the internet & back in again is NAT loopback & TalkTalk has always blocked this due to a security vulnerability. To test, use a smartphone & disconnect it from your WiFi, then access the web server via the DDNS domain via mobile data. To access the webserver locally use its private IP address.
