Huawei MT992 - internet Led/Light
coinup
Message 13 of 13
I'm on a G.Fast 300mbps service, with a Huawei MT992 modem connected to a third party router.
I have only just noticed this but the internet led/light on the modem is not on/flashing, but
yet I have a stable internet connection. Has the led failed or is there another issue?
12 REPLIES 12
Message 1 of 13
Hi Graeme,
If you need assistance can you please start your own thread/topic and we'll be happy to help
Graeme25
Message 2 of 13
The internet light on my Open Reach modem doesn't light up and I am getting persistent outages. I've reset to modem but the problem has persisted throughout most of December. The talk talk message service is rather poor I'm afraid. You wait hours to get nowhere. I've checked out local outages and none of them coincide with my issue. I need this to be solved as I rely on the internet for work. Any ideas of how to proceed from here?
thanks
Graeme
coinup
Message 3 of 13
I'll try a live chat with talktalk.
Message 4 of 13
Hi coinup,
As advised, please can you create your own topic and we can look into this further for you.
Message 5 of 13
Ah, I know, I get it. But to paraphrase a well known old adage: if it ain't broke, then TalkTalk can't fix it!
coinup
Message 6 of 13
Apart from the light, yes.
Just wanted peace of mind.
Message 7 of 13
Ah! Sadly that can be unreliable. Back to where we started: is your service working OK?
coinup
Message 8 of 13
I dont think so, but the online line checker saying more investigations need to be done.
'We've found an issue that requires a refresh of your connection'. this is the second time its done this just by checking.
Message 9 of 13
Has the connection now failed? If so and this is down to the modem then it should be replaced free of charge.
coinup
Message 10 of 13
I might be having problems.
How much is a new, MT992 and does a Openreach engineer have to be on site to install
Message 11 of 13
Thanks for your post. If your connection is working ok then I wouldn't worry about this but if it does start to cause any issues then please let us know.
Message 12 of 13
Personally, if everything is otherwise working as it should then I wouldn't worry too much. The support team will of course advise further when they are back online tomorrow.
