on 13-05-2023 02:14 PM
Hi, I am having trouble with the wifi not connecting to quite a few devices reliably. It keeps on dropping out on several TV’s and sky boxes, it is also intermittent on mobiles as well. On the dashboard there is a long list of devices which have trouble connecting reliably. I have tried turning the router off for 1/2 hour and re-starting it, and I have also disconnected and re-connected the devices, and it still has trouble connecting reliably. Is this a router issue? I see on the website there is the new Amazon eero router, would this work any better and reliably?
on 09-06-2023 06:23 AM
Hi Mark1988
I have posted on your other topic on the Community.
on 08-06-2023 05:52 PM
For the support team: OP also has another thread, just annotating that to avoid any confusion and/or duplication.
https://community.talktalk.co.uk/t5/Fibre/Faulty-Router/m-p/2974945
on 08-06-2023 05:33 PM
Hi Keith, sorry I missed your reply, I don’t think the eero router would work for me then, I have quite a big house and would have to buy a lot of units to make it work.
it is a problem with the router and not interference, I had exactly the same problem a couple of years ago, they sent a new router through and that worked for a little while, but has stopped working again now. The signal goes on everything I try and use unless I am within a couple of meters of the wifi hub. I have tried calling the talk talk support phone number, and they were very unhelpful, hopefully the people that look after it on here will be more useful.
on 13-05-2023 04:31 PM
The Eero is sold on its own, but without purchasing extra units to create a Mesh network, the coverage is often disappointing. It is designed to be used as part of a mesh.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
13-05-2023 02:22 PM - edited 13-05-2023 02:27 PM
I forgot to say, I had the same issue in August 2021 and received a new router, this worked well for a while but has gone back to having the same problems again. Is there anything that can be done, or can anyone recommend a different router with better range and reliability to the TalkTalk wifi hub (it is FAST 5364-4.T8). It was replaced last time, and has gone back to having the same issue less than two years later.
on 13-05-2023 02:16 PM
