Internet Disconnecting
Marie37
Message 6 of 6
Roughly once an hour my internet connection is disconnecting. I have fibre to the cabinet. The light on the router goes red and it reconnects after approximately 2 minutes. This is causing issues when I am in video calls working from home.
Do I need to login to my Sagemcom router and change the settings?
Many thanks
Marie
5 REPLIES 5
Message 1 of 6
Hi Marie,
How are you getting on?
Message 2 of 6
Hi Marie,
Thank you. I've run a test on the line which is clear, however I can see a few re-connections on the line. Is your voice service ok with no noise on the line? Does your main socket also have a test socket please?
Message 3 of 6
I have added my name and landline number to my Community Profile.
Best wishes
Marie
Message 4 of 6
Message 5 of 6
Hi Marie37
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
