No Internet but white light on router
RossM_WGC
Message 19 of 19
As per the title, either wireless or wired.
I've restarted the modem and router numerous times but it's been down almost 24 hours . The tech chat can't see a problem on the line but they can't send a Brightsparks engineer for 10 days.
The internet light is not on on the Openreach modem but if I log onto the router, the internet connect status is 'connected'.
Finally, when I ping the Google server in CMD, the DNS request times out in 2 seconds. Suggesting no internet connectivity.
18 REPLIES 18
Message 1 of 19
Thanks for the update, glad to hear it's working now. I'm sorry, I don't know what caused the issue but if you do experience any further problems please let us know
Message 2 of 19
Good morning Chris, the service started working after 7pm last night and the phone line now has a normal dial tone. Are you able to determine what the issues (s) was\were? It's a concern that they appear to be unexplained.
Message 3 of 19
Hi RossM_WGC
I've made a change at our end, could you just check your phone line and let me know if anything has changed
Gliwmaeden2
Message 4 of 19
Staff will be back on here early tomorrow, @RossM_WGC
Message 5 of 19
I have a Brightsparks engineer booked for the previous issues, but this appears to be a new issue. When I ring the landline the call goes straight to voicemail. Surely there's an issue with the line?
Message 6 of 19
We can arrange an engineer visit to investigate. If you'd like us to do this please let us know and we'll confirm some details with you
Message 7 of 19
Sadly, not. But it was working when I tested this on Sunday when we had the initial unexplained outage.
Message 8 of 19
Do you have another telephone handset that you can test with?
Message 9 of 19
Thank you. No, it was plugged in to its usual socket. However I have just tried the Openreach socket and I'm getting the same beeping tone.
Message 10 of 19
Line test is clear. Is your telephone currently connected to the test socket?
Message 11 of 19
OK thanks, I'll run a line test on the voice side, I'll let you know how I get on
Message 12 of 19
Ah, it must be a different issue, as we're now getting a beeping tone and cannot make any calls on the landline.
Message 13 of 19
Hi RossM_WGC,
Line test is passing, shows one reconnection yesterday and nothing so far today. Are you experiencing any problems with your telephone service, any noise on the line?
Message 14 of 19
Hi Michelle,
I have lost internet connection again this morning. I am in the process of rebooting the modem and router but are you able to test for issues on the line?
Message 15 of 19
Thanks for confirming and I'm glad to hear this. If this does happen again and there is also no connection at the Openreach modem with the router removed, then we'll have to arrange an engineer visit to the property for the Openreach modem to be checked.
Message 16 of 19
Thank you for looking at this promptly.
It was not working late last night but it was working at 6am this morning, although the 'Internet' light on the modem is still not on. It's very odd, as I would not describe this an intermittent fault due the outage lasted close the 24 hours.
Message 17 of 19
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault and the line is showing in sync, however I can see quite a few re-connections on the line. Is the light still off on the Openreach modem at the moment?
Message 18 of 19
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
