No lights showing on router
Taffy57
Message 17 of 17
I noticed last night that the internet connection light on my router was off, when i checked the speed it was showing 8mps, I am on Fibre 65, after rebooting the router the internet speed has risen to 53mps (normal) but still no light showing. i have had trouble speed fluctuations in the past do you suggest i need a replacement router
16 REPLIES 16
Message 1 of 17
Hi Taffy
That's great 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 17
Hi Debbie
So far so good I've not had to reboot my router and its giving a constant speed averaging 55mbps.
I will keep an eye on it and get in touch if any other problems arise.
Thanks for your support
Taffy
Message 3 of 17
Hi Taffy
How are you getting on, how's the connection been?
Message 4 of 17
Hi Taffy
That's great 🙂
I will check in again with you on Friday to see how the connection has been.
Message 5 of 17
Yes I've received my replacement router and just set it up, current speed showing 60 mbps which I've never had before.
Will leave it two or three days to see how it goes then get back to you with the results.
Taffy.
Message 6 of 17
Message 7 of 17
Message 8 of 17
 I certainly will let you know how it compares.
Thank you
Taffy
Message 9 of 17
Hi Taffy
Message 10 of 17
The line to the router is always good its just from the router to devices that's the problem, if you think I should try a replacement router i am willing to give it a go.
Taffy
Message 11 of 17
Good afternoon Taffy,
Thanks for confirming and I'm sorry to hear this. I've re-checked the connection stats now and the connection stats look ok. Please let us know if you'd like to try the replacement router to see how this compares.
Message 12 of 17
Hi Michelle
I have had to reboot my router twice since reporting the issue, at the moment speed is showing as 51mbps. still no white light showing.
I will post attachment showing the speed when it drops off again.
Taffy
Message 13 of 17
Morning Taffy,
Just checking back in to see how your connection has been since your last post?
Message 14 of 17
Taffy57
Message 15 of 17
OK thanks
Chris-TalkTalk
Message 16 of 17
Hi Taffy57,
Line  test isn't picking up any issues. I would see how it goes and if problems continue we can send another router to test with?
