Removing a unwanted item from my devices on router
Weevie
Insightful One
Message 2 of 2
How do I remove an unwanted item from MY DEVICES on my WiFi hub ?
The item is an old phone - no longer in existence, since about 5 years ago .... it has no IP address against it - but still appears on the 2.4Ghz list
1 REPLY 1
Divsec
Message 1 of 2
Hi @Weevie well if you are feeling brave you could factory reset your router, taking care to note your existing SSID, password, and any special settings you have acquired over the years.
Personally I couldn't be bothered and the old phone is just that, a distant memory not likely to return and steal your WiFi?
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
