on 17-08-2024 01:37 PM
I am up for renewal and been offered fibre 65 (what I have now) or Full fibre 150 both for the same price of £28.
Will the full Fibre 150 come with the Eero because its no use for me as most of my devices are connected via wire and they do not have wifi capability.
Looking at photos of the back of the Eero am I right in thinking that it only has 2 ports for a wired connection.
Is there a faster option than my current fibre 65 that is not Full fibre -one that I do not need a new line/cable installing from the pole to my house.
Thank you community.
on 18-08-2024 10:43 PM
As I understand it they can only run a cable outside the house to an entry point that suits where you want the ONT to be directly on an inside wall, not internally. At the end of the day you can but place an order and then, when they turn up, if they cannot meet your wishes then you can cancel it. There are physical limitations.
on 18-08-2024 10:32 PM
So if they used a splice machine all that is inside that outside box is what looks like a continuous cable not connected to anything.
I am wondering why cant they put the cable through the wall without any box and then splice on a plug on the end inside the house.
I sort of get it that if they put on a plug outside the house then it would then need a bigger hole to thread it in.
Why do you think that following the current path of my copper will not be feasible.
Before I agree to fitting full fibre is there a way i can discuss my preferred route with the engineer.
on 18-08-2024 10:20 PM
They used a splice machine. If you don't want it at the front of the house then the engineer can arrange it for elsewhere, within reason. You do have the option to discuss that at the time. I have to say in all honesty though that replicating the current path as you have described may not be feasible. For me, that's just the way my setup was with the old copper line and it doesn't bother me in the least.
18-08-2024 10:11 PM - edited 18-08-2024 10:11 PM
Mine will be from above. That black cable looks that same as the one that goes into the external box. I dont see the need for the external box.
Did they use a splice machine or was the one from the ground just plugged into a terminus in the outside box.
on 18-08-2024 10:07 PM
I do not want an external fibre termination box on the front of the house.
I have a house extension set back 1/2 a brick with integral garage with a bedroom above. there is a tiled canopy from the front door to the end of the extension covering the garage door and currently the copper cable comes down from the eves running in the corner of the 1/2 brick step back into the canopy roof space in the corner then into the garage through a hole in the wall and then into to house from the garage. The BT box and router are directly on the other side of the garage wall in the house at the front of the house.
Is there any reason why the new full fibre cable cannot follow the same path and the termination box be sited in the integral garage out of sight. And for that matter the ONT - I have power for it in the garage.
on 18-08-2024 09:59 PM
Personally, I was interested (sad?) enough to ask my installing engineer if I could watch the fitting process! The incoming cable is indeed connected to the entry box and then a separate run connected through the wall to the ONT inside. Here's what my installation looks like. Bear in mind that this is Openreach rather than another supplier. And I was lucky enough to have the fibre cable blown underground via existing ducting.
on 18-08-2024 09:51 PM
I can only think that the pole cable is stiffer and less flexible than the one that goes through the wall to the ONT.
So is there any arc splicing involved or does the cable from the pole just "plug" into a terminal in the external fibre termination box.
on 18-08-2024 09:41 PM
I don't have an explanation for that, it's just what they do.
on 18-08-2024 08:42 PM
Thanks @ferguson for the explanation of the fibre 150 "stopgap"
I understand the fitting of the full fibre just not the need to have an external fibre termination box which they then need to splice to a shorter cable to go through the wall to the ONT.
on 18-08-2024 08:31 PM
Fibre 150 will only be available in very limited areas, probably not at all if you have Full Fibre available to you. It is a G.Fast product which is essentially a souped up FTTC service. Introduced by Openreach a few years back as a stop gap and being phased out along with other copper based services. Full Fibre requires the cable to enter your home and then connect directly to an ONT, think of that as working like a modem from which you can then connect your router.
on 18-08-2024 08:25 PM
Another question is does there need to be the outside box that then goes into the property and then connects to the ONT.
Why cant the cable from the post go directly into the house like the old copper.
Is it because the black post cable is sort of strong and armoured and not easily connected to the ONT
18-08-2024 08:17 PM - edited 18-08-2024 09:20 PM
With the help of @Gliwmaeden2 first reply I have done some more reading and now understand what is involved with the install of Full fibre and if I do go for it then I can order the sagecom hub 2 and simply plug my phone line directly into that and still have my 4 ports. Rather than Eero which would also need an extra adapter for VOIP and I wouldnt have the 4 ports.
I dont see the benefit in going Full fibre 150 if I can have fibre 150 without all the extra cabling and fitting and socket.
The small print tells me that normal 150 is available but at a cost of £35 when Full fibre 150 is £28. There is a further complication that I currently have a deal with an all calls boost that I need to negotiate.
on 18-08-2024 08:08 PM
I have been away so could not answer. Thank you for all your help - I actually welcome all input.
I found the bit about the small print was interesting and helpful.
on 18-08-2024 08:04 PM
Topic now reopened for the original poster to follow up.
on 18-08-2024 06:43 PM
@Marvel, I am locking this thread as your topic has been hijacked by another customer.
I hope you have found a suitable deal.
on 18-08-2024 03:33 PM
You've hammered that point in the past (and that's good), that if one wants VOIP, whether a new customer, or an existing customer upgrading, you have to specifically mention that, while entering a new contract. It would be nice if new customers were aware of that, which they won't be.
Now, at https://www.talktalk.co.uk/broadband/deals-existing-customer,
I was hoping to find something of substance as an existing customer i.e. 'deals' as an existing customer. I did not find it.
'Small Print' does not mention whether it's for new or existing customers. I can't see why it would be for one or the other.
So the 'Small Print' should include something about VOIP , seeing that it is 'Small Print' .
Thank you.
Bill
18-08-2024 01:53 PM - edited 18-08-2024 01:55 PM
VOIP with Talktalk can only be fixed up by phoning in or using Chat at the same time as placing the order, @Billx.
They are not offering it as a deal for new customers and so doesn't show.
It can't be added separately later even by current customers, nor through My Account, hence it not showing on the Web interface.
Anyway, the original customer has specified that they don't want full fibre but do want faster speeds.
Please don't clutter up their thread with this red herring.
18-08-2024 01:45 PM - edited 18-08-2024 01:49 PM
When you go to that page, https://www.talktalk.co.uk/broadband/deals-existing-customer, there is no indication that there might be something below the bottom of the screen. The only indication is to login to your account, as an existing customer.
Yes, there is something below the bottom of the screen, and right at at the bottom of the page, there is 'Small Print'
However, the 'Small Print' is NOT complete. For instance, in my case I have 'Full Fibre 65 with VOIP'. Nowhere can I find that specification, or any other specification mentioning VOIP.
Thanks, @Gliwmaeden2
Bill
18-08-2024 01:18 PM - edited 18-08-2024 01:20 PM
@Billx, I was referring to the small print on that page, if you read more carefully.
That equips customers to phone / Chat, as I specifically mentioned, & I never recommend going through the My Account route.
Thank you!
18-08-2024 12:09 PM - edited 18-08-2024 12:12 PM
Hi @Gliwmaeden2
That link, https://www.talktalk.co.uk/broadband/deals-existing-customer
forces one to log in to MyAccount, from there you have to choose 'Upgrades and offers', which does not provide anything useful. It just offers one or two TV add-ons, or a bribe when one 'Refers a friend to TalkTalk'.
Bill
