Router DG8041W restart kernel panic
coastwalker
Message 6 of 6
Router details:
Device Type: DG8041W
Description: EchoLife DG8041W Home Gateway
Hardware Version: I.1.01
Software Version: v1.05t
Router is restarting regularly, sometimes multiple times a day with a kernel panic alarm.
1981-01-01 00:00:10 [Error][Alarm-Log] AlarmID:104001,AlarmLevel:Error,Device reset. Cause: System reset due to kernel panic, Terminal:OTHER
Would a firmware update resolve this?
Can you supply me with the file so that I can update the firmware?
5 REPLIES 5
Message 1 of 6
coastwalker
Message 2 of 6
Thank you Debbie. I will test the replacement and report back. Appreciate the swift help.
Message 3 of 6
Hi coastwalker
Apologies for this.
I've ordered you a replacement router, please allow 24-48hrs for this to arrive.
coastwalker
Message 4 of 6
Ok, thank you very much. My usage case means that this week the disconnects are tolerable so I will see if the issue gets resolved over the next few days.
Message 5 of 6
This router is no longer maintained. I have asked one of TalkTalk's support to pick your thread up and replace it for you.
