on 17-02-2024 02:57 PM
Hi.
I'm really at my wit's end with this. I've had the same TalkTalk router for a number of years and it has mostly worked fine (I had a few issues last year with kernel panic that were resolved by a firmware update but in the last few days, the router has been continually restarting with the above error message appearing in the User Log. I have spent a number of hours on webchats with TalkTalk and feel that I am being fobbed off and being asked to perform the same steps over and over again which make no difference whatsoever.
Having found the community to be extremely helpful when my kernel was panicking, I am wondering if anyone can suggest a course of action to help me fix this issue. On one of the webchats, I think the agent did a factory reset on my router remotely so not sure what firmware I have now.
Many thanks in advance,
Rob
on 17-02-2024 03:18 PM
OK thanks for that. That firmware has been trialled on a few customers & seems to be unstable. I have asked one of TalkTalk's support to pick your thread up and downgrade it for you.
on 17-02-2024 03:12 PM
Hi Keith,
The firmware is 1.08.
Thanks,
Rob
on 17-02-2024 03:10 PM
Which firmware is on your DG8041W, 1.05 or 1.08?
To find out, please log into the router & go to:-
Dashboard > See Internet Settings > Manage advanced settings > System Info > Device Information
