Router not connecting after power cut
KatiT
Message 12 of 12
After a power cut today (6 hours) i have lost my internet connection. Orange light continuously flashing. My network no longer appears in my list. Tried everything, even resetting my router but no joy. Please help!
KatiT
11 REPLIES 11
Message 1 of 12
Hi @Brijesh123
I'm sorry to hear this. Please can you create your own topic and we can look into this further for you.
Brijesh123
Message 2 of 12
I hsve same issue today and pathetic chat bot service nobody coming for support waiting for ages
Message 3 of 12
Hi @KatiT
I'm so glad to hear this, thanks for letting us know 🙂
I've sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 4 of 12
Hi Debbie,
The replacement router arrived today and was set up and running withing minutes! Was able to set up other devices on wifi with no problems. Also appreciate the return of the old router - a great policy! Will get that sent off asap.
Many thanks for your help and speedy service!
Best,
KatiT
KatiT
Message 5 of 12
Message 6 of 12
Many thanks again Debbie. I will let you know when the router arrives and I have set it up. Hopefully everything will be back to normal!
Best,
KatiT
KatiT
Message 7 of 12
Hi KatiT
Thank you 🙂
Thanks again.
Message 8 of 12
Thank you Debbie.
KatiT
Message 9 of 12
Hi @KatiT
Please can you add your TalkTalk landline number to your Community Profile, we can then send a replacement router.
Message 10 of 12
yes, I turned the router off for over an hour, checked all the connections. Finally this evening I connected my old Talktalk router which got me connected to the internet. I think the problem is the router itself.
KatiT
Message 11 of 12
When you say reset, have you tried turning it off for a full 30 minutes before turning it back on again? That may fix the connection, unless that itself is down.
This has been flagged to the support team here for you and they should pick it up tomorrow.
