on 07-11-2023 04:07 PM
About 3 months ago our internet speed suddenly dropped to around 31mbs, whilst our service guarantees a minimum of 44mbps. The engineer could not fix the issue. We've had re-sets and new routers, but the problem prevails. Any ideas anyone? Any idea how I get some form of rebate perhaps on my monthly fee? Ta. Paul
on 08-11-2023 07:00 AM
Hi dc981
The line is showing in sync at 55mb.
Please can you power down the router for a full 30 minutes and then run another speed test?
on 07-11-2023 04:13 PM
2. Assuming that you do not have full fibre, if you log into the router, what speeds does it show there (normally in the initial dashboard area?
3. If you have any wired connections, are they affected in the same way as wireless ones?
