Streaming problems with eero Pro 6
Butterfly17
Message 4 of 4
Hi, ever since I upgraded to eero pro 6 I have had problems with streaming with constant buffering. I didn't have this problem with my old router on fibre 65 apart from when it became faulty and kept cutting out turning the internet off completely but no streaming issues. I am suppose to be on 500 MPBS but the streaming service is far worse than when I was on 65 MBPS. Is there a way to fix this? There seems to be an issue with the eero pro 6? TalkTalk say they have upgraded the firmware but the issue persists. Thanks.
3 REPLIES 3
Message 1 of 4
Is this device connected to the 2.4GHz band, because it does not support the 5GHz band?
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 2 of 4
Thanks for your reply. It seems to be connected to 2.4 GHz. The download speed is showing as 516 Mbps / Upload 71 Mbps updated at 4.43 am. I understand, I guess I just wasn't expecting this as didn't have these type of streaming/interference issues with the previous router, although did have other issues but was hoping for an improved service with the upgrade. Yes please could you send me the guide. Thank you very much.
Message 3 of 4
Hi @Butterfly17
Which WiFi band on the Pro 6 is the device connected to? In the eero app, if you tap on the Internet on the Home screen, what speeds does it show at the bottom?
Whilst the eero is supposed to manage Wi-Fi interference, if this is very bad, particularly in the 2.4GHz band, then it cannot do anything about it, no router can. The same goes for any router at that point. Other things that may then need to be investigated are its location within your property and the WiFi bands that you use. It is possible that you may also need to purchase additional eero nodes as it is supposed to operate as part of a mesh system. I can help with any of this. However, I would suggest that you follow my help to find out what the root cause of the problem is, before throwing money at it.
Anonymous User
