Loss of speed
Fishy25
Message 3 of 3
I have talked for over 1.5 hours with the help desk on message to cure the problem of speed dropping after 6pm at night until 6am the next morning I know I am getting 17mb to the router the problem happens after the router I have checked many different devices and they are all working fine but still show the same result when doing a speed check I am at a loss to what I can do next
Paul Fisher
Message 1 of 3
I've run a test on the line now which is clear. Are the speeds also low if you connect wired?
Message 2 of 3
Are the speeds also low if you run a wired speed test too?
  • Name
  • Telephone number or Account number
  • Alternative contact number
