on 02-07-2023 04:29 PM
Could someone at TT please turn off WiFi optimization on my TT Hub Sagemcom router, please?
One of my devices gets dropped as I change the channel to meet conditions at specific times so I'm happy to conduct periodic network reviews and optimisations myself.
My phone number is in my profile.
Kind regards
on 07-07-2023 09:51 AM
Good Morning,
Thanks for your post. Please can you create your own topic and we can then switch this off for you.
Thanks 🙂
on 07-07-2023 09:50 AM
How do you turn off WIFI optimisation as I have set the router to manual channel 11 but 24 hours later it reverts to channel 1 both my neighbors are using this channel.
on 06-07-2023 06:29 AM
I'm really glad to hear this and thanks for confirming 🙂
on 05-07-2023 02:43 PM
Thank you,
Router is now holding the channels I select for both frequencies as I hoped it would.
I completed the survey detailing my positive experience.
Great support again from TT; proud to be a customer, thank you
on 04-07-2023 07:33 AM
Hi guerilla
That's great news, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Debbie 🙂
on 04-07-2023 07:29 AM
Thank you so much @Debbie-TalkTalk
WiFi is holding designated channel in both 2.4 and 5GHz frequencies now so I hope the unreliable connection holds.
Thank you for such a swift resolution!
Have a good one 👍
on 03-07-2023 06:52 AM
Hi guerilla
I've switched the WIFI optimisation off as requested, please let us know how the connection compares.
