VOIP via TalkTalk and CityFibre
mrwrighty
Enlightened One
Message 2 of 2
I’ve been away from the community for a while and was wondering if anything has changed on the VOIP front. I have the Fibre 65 and still have my phone number which I would like to keep. I would also like to upgrade to 500mb service but previous enquires meant losing access to our phone which is important for elderly relatives.
it is not clear if I’m able to port my number away from TalkTalk to a VOIP provider if TalkTalk cannot provide a VOIP service. I’ve been told previously that porting the number would disconnect my fibre service as the 2 are currently linked so appear to be in stalemate.
1 REPLY 1
Divsec
Message 1 of 2
Hi @mrwrighty welcome back, you haven't missed much apart from a management decision to make all the familiar superb community team redundant.
I think you might be better calling retentions on 03451720088 as you question is both complicated and contractual,you might even get a deal!
Regardless your post has been escalated.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
