Very slow internet since Saturday
paschal7
Message 9 of 9
It is over 36 hours I have been experiencing very slow internet, logged a case since then, and was told my issue is being resolved. Nothing has changed since then.
What is actually going on?????
Paschal Anuforo
8 REPLIES 8
Message 1 of 9
Thank you for confirming. I've passed this over to our Faults Escalation Team and I will let you know as soon as I receive an update back. It's also possible that the team may contact you directly.
Message 2 of 9
I am using the WiFi hub. I have checked with another device as directed, but the result is the same.
Paschal Anuforo
Message 3 of 9
What speeds were you seeing previously? Could you try removing the router and then connecting a device wired directly at the ONT please and then run another speed test. This will help to rule out if the issue is with the router. Are you using an eero or the Wifi Hub router please?
Message 4 of 9
If you read my last msg, you will see where I confirmed to have done the power reset and still didn't get any different result.
Download 147 Mbps
Upload 156 Mbps
Been like this in over 60hrs now!
Paschal Anuforo
Message 5 of 9
Hi paschal7,
What sort of speeds are you getting? Could you switch the ONT off and leave it off for at least 30 minutes then switch back on an retest
Message 6 of 9
I have powered down my router for more than 30 mins, nothing has changed.
However, I don't expect to be getting troubleshooting tips at this point.
I expect to be getting a resolution! An expert/engineer should already have identified the issue at this point.
I have not been able to do any reasonable work since this issue started.
I need a solution immediately please!!!!
Paschal Anuforo
Billx
Message 7 of 9
As you are new user of this community website, @paschal7
it will help the staff helping you, if you enter some of your details in the Community Profile.
You can enter your TalkTalk telephone number, or you MY ACCOUNT account no.
Bill
Message 8 of 9
Hi paschal7
Can I just check, do you have an FTTP connection? Have you tried powering down the router for a full 30 minutes?
