Wi-FI inadequate
mantalk1
Message 12 of 12
The wifi in my house is inadequate.  I have only 5 devices connected via wifi. However adding any more devices causes the  connections to drop, causing  major problems. Dead zones despite the fact that I also have an extender upstairs.
My son who is with EE had similar problems and complained to EE, whereupon  EE sent an engineer to the house to resolve the problem. They established a Mesh connection system  and his Wi-Fi now works perfectly.  My son suggested that I talk to you and see if you would send an engineer out to check and sort out this problem. Hence my request to you, to kindly do the same.
11 REPLIES 11
Message 1 of 12
Hi mantalk1
I'm glad to hear that everything is working ok with the router and WIFI extenders.
Yes please can you return the old router using the pre paid returns bag.
Message 2 of 12
Hi Debbie,
Received the router. It improved my broadband download speeds from 34Mbps to 41Mbs which was nice,  butit did nothing for the wi-fi problem. However one of the talktalk customer services sent me a wi-fi extender and that seems to have done the job! Getting good signals upstairs now. Should I return the old router to you?  A returns bag was enclosed with with the new one.
Message 3 of 12
That was going to be my first suggestion as well @mantalk1.
If you need any further help with this after you get the new router, let me know.
Message 4 of 12
Hi mantalk1
I have ordered a router for testing, please allow 24-48hrs for this to arrive.
Message 5 of 12
I have updated my Community profile as requested.
mantalk1
Message 6 of 12
I have done as requested and updated my profile
Message 7 of 12
  • Name
  • Telephone number
  • Alternative contact number
mantalk1
Message 8 of 12
Thank you Michelle. Yes please send me a better and a new router. Hope this fixes the problem.
Message 9 of 12
Would you like us to send a replacement router for testing purposes to see how this compares? This would be a Wifi Hub router.
mantalk1
Message 10 of 12
D-link 3782 Super Router
Message 11 of 12
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
