Wi-Fi dropouts
Message 14 of 14
Im having regular Wi-Fi dropouts with my WiFi hub. When I try certain Wi-Fi channels it seems to help but it changing itself to a different channel after a short time. Can I please request for Wi-Fi optimisation to be turned off?
13 REPLIES 13
Message 2 of 14
 No worries @Anonymous
Message 3 of 14
Hi @Anonymous
I'm so glad to hear that the connection has improved.
If you do experience any further issues then please let us know.
Message 4 of 14
Hi @KeithFrench
Thanks for the offer to help but I’ve managed to get the dropouts to stop and the overall connection is actually better than it was before the dropouts started. I don’t think there’s any need to go further with this.
Message 5 of 14
Hi @Anonymous
If you would like to PM me (to protect your privacy) with as many screenshots as you can from your analyser, then I'll take a look at them.
Message 6 of 14
Hi @KeithFrench
I have also found that on the 5GHz band certain Wi-Fi channels have a stronger connection throughout the house as well as no dropouts. I do also use a Wi-Fi scanner which isn’t super detailed but does give the RSSI levels and Wi-Fi channels of all networks in my area. Just so you know I have the Sagemcom FAST 5364 Wi-Fi hub.
Message 7 of 14
Hi @Anonymous
If you look back at one of my earlier posts, I offered to help you. I would never recommend changing channels without reference to a WiFi analyser.
Message 8 of 14
Hi @Debbie-TalkTalk ,
I have found that manually selecting some Wi-Fi channels are causing dropouts and others are working fine with no dropouts. Before turning off Wi-Fi optimization is would regularly change channels sometimes causing dropouts and sometimes not. So a definite improvement me being able to manually change the channel and it not then changing itself to a different one causing dropouts.
Message 9 of 14
Hi @Anonymous
How's the connection been since the WIFI optimisation was switched off?
Message 10 of 14
Hi nick66522
I've switched the WIFI optimisation off as requested, please let us know how the connection compares.
Thanks @KeithFrench
Message 11 of 14
When TalkTalk has disabled WiFi optimisation, if you want my help, please let me know.
Message 12 of 14
Thanks for replying. Wired connections work absolutely fine with no problems, it’s only wireless connections dropping out regardless of strong or weak signal.
Message 13 of 14
I have asked one of TalkTalk's support to pick your thread up and disable WiFi optimisation for you.
