WiFi disconnecting devices
Durham10
Message 25 of 25
For the last few weeks some of the devices connected to wifi keep randomly disconnecting.  We then have to switch the WiFi off or reconnect the device. It’s not a loss of wifi as other devices remain working and the white light is on the router. It’s not the distance from the router either as some are right next to it or are in the same room.
24 REPLIES 24
Message 22 of 25
Hi Keith
We have the Sagemcom Talktalk Wifi hub
Message 23 of 25
Hi @Durham10
I can see that our Community Star @KeithFrench has offered to help.
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue.  Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others.  If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc.  one of the TalkTalk team will jump in and help out.
Message 24 of 25
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
