on 11-10-2023 05:55 PM
Would really really love to upgrade to full fibre 150. im on fibre 65 at the minute, with the talktalk hub. everything is brilliant with this talktalk hub, we live in as two bedroom bungalow and steady speeds everywhere, even out in front garden and back. The router is up in the attic with 4 ethernet cables attached. Question is, if I did upgrade, could i still use the talktalk hub. read somewhere that I could still use the router. just want to get it verifyed. Thanks
on 12-10-2023 07:12 AM
Hi delmoon,
If you have the sagemcom then it will work with full fibre but it doesn't have a voice port for VoIP telephone service. The router may need to be relocated too. - How Full Fibre is installed - TalkTalk Help & Support
