auto wifi connection without passcodè new router
roc123
Message 2 of 2
Why has my replacement fibre router automatically connected to lap and Xbox also ring door without password code?? concern about security?
1 REPLY 1
Message 1 of 2
Hi roc123
The routers do not have open Wi-Fi so would only connect if you've used something like wpa or set up devices using a mobile etc that can pass Wi-Fi details across. You can log into the router to make sure the password is set up.
