changing to fibre 150
Sparkyneal
Message 6 of 6
Does anyone actually know what the engineer will do when he comes to upgrade my standard broadband to fibre 150? I have copper cable to phone socket so no overheads etc or fibre to house as such....
5 REPLIES 5
Message 1 of 6
Just to add, if it's an upgrade to G.fast then an engineer would also install a modem too.
Message 2 of 6
brilliant - thanks for your help!
Message 3 of 6
If it's not a FTTP upgrade then the set up should remain the same if you already have a Openreach main socket installed.
Message 4 of 6
Hi Michelle,
No this will be still a mix of fibre to the cabinet and copper underground so I assume they wont be doing anything in the street - only inside changing the router?
Message 5 of 6
Thanks for your post. Do you mean to FTTP? I've included a Help Guide below,
Guide to Full Fibre and FTTP | TalkTalk
Michelle 🙂
