on 12-06-2024 08:07 PM
I have ordered full fibre which comes with an eero router the question is can I add my own extender eero and not rent Talktalk's own.
Thursday
It's not a problem. For example you could connect a switch to the main unit and then connect other devices, including the ATA, from there. Or on the secondary unit. Or even both, whichever suits you best.
Thursday
The problem is the main Eero unit will be next to the phone downstairs which needs an ethernet connection and I also need an ethernet connection upstairs this is why I have asked if any of the Eero extenders have ethernet sockets/
Thursday
If you want additional ethernet ports then you can get a switch, many examples can be found on a well known website. Other retailers are of course available. 🙂
Thursday
Do you know which Eero extenders that have an ethernet connection as it need to connect tv etc
Wednesday
If you already have an eero then you should be able to add that as part of a mesh system.
