keep losing connection and speeds half
Stratoc1
Message 22 of 22
Hi, my speed dropped from 64 mg to under 30 Wednesday, disconnected router for 30 minutes, re connected it all was fine. I then ran a line test on Talktalk website and got a text saying please contact us, as connection was fine I didn't. Last night I got a text saying Openreach have found a problem with your line and ETA for fix is tonight. Followed by one saying it was fixed.
Next morning I noticed the wifi was missing from my phone and red light flashing on router, it reconnected at about 57 meg so I assumed that was okay.
Was fine all day, been working this morning and lost connection again, reconnected at just under 30 again? Any ideas?
I ran another test and it says they have identified a fault and there is a chat now button that doesn't do anything?
21 REPLIES 21
Message 21 of 22
2. What package are you on? If Fibre 65, is this Full Fibre or FTTC & copper wires to the property?
3. If you have any wired connections, are they affected in the same way as wireless ones?
