port forwarding not working
_ozzy_
Message 24 of 24
oh hey, it's one of those "port forwarding is not working" posts!
router is HG633
have made a new port mapping application, tcp/udp with correct single port
have made a new port mapping and assigned it to my machine as local host (mac laptop, wireless)
not able to connect to server running on machine
port opening online sites report port is closed.
unsure how to proceed, not able to verify the ip being used with the port, can only use e.g. "what is my ip" to show external ip - unfortunately the help says can click on device icon to see the ip but this does not work
can anyone suggest things to check, or points of possible error?
many thanks
23 REPLIES 23
Message 1 of 24
Please let us know how you get on 🙂
Message 2 of 24
great,
many thanks
Message 3 of 24
I've ordered the router, it should be with you within a couple of working days
Message 4 of 24
Ok thanks, I'll take a look at this now
Message 5 of 24
argh, sorry had a typo
has been corrected, sorry about that
Message 6 of 24
OK thanks. Could you check the telephone number in your community profile and confirm that it's your TalkTalk landline telephone number
Message 7 of 24
done, thanks
Message 8 of 24
Hi _ozzy_,
Thanks but could you add the account holders name to private note section of your community profile
Message 9 of 24
hoorah! name and number updated, please let me know if there's any additional info you need
thanks
Message 10 of 24
Hi _ozzy_
Please can you add your name and TalkTalk landline number to your Community Profile, I can then send the router. There will be no charge for this router.
Message 11 of 24
hi,
sounds like i'm running out of options to get my system working so yes, this would be great thank you
would there be any additional cost?
many thanks
Message 12 of 24
We can send a replacement router (Sagemcom wifi hub) and a router returns bag so that the original router can be returned. Would this be ok?
Message 13 of 24
Watch this space.....
Message 14 of 24
sure, that would be great, thanks!
Message 15 of 24
Of course your router is now old & no longer supported, it might have a hardware fault on it. Would you like me to see if TalkTalk will replace it with something newer?
Message 16 of 24
sorry i'm not sure how to check for that on a mac (do you know?)
on my mac's firewall i just list applications that should allow incoming connections, and i do have my server app listed - i did try disabling the machine's firewall completely to see if that resolved the issue - still could not connect with it disabled, so i don't _think_ that is the problem. i will try again later.
thanks
Message 17 of 24
I would have tested this fully myself, but I no longer have one of these. On your PC's firewall rule, it will obviously be presented to the PC on its 192.168.1.x IP address. Does your rule allow for this?
Message 18 of 24
i see
do you have any suggestions? i tried enabling dmz for this machine, didn't seem to help
many thanks
Message 19 of 24
This router identifies the device by its MAC address when port forwarding.
Message 20 of 24
hey,
this machine does have a firewall, but the server app is whitelisted - and i've successfully connected to the server on this machine before using a different router
yes, machine connects directly to the router.
hm good question. i think just udp - however i did try changing the rules to be tcp only, purely to try a "connect to port" online site, but this still reported it as closed.
the thing i'm most suspicious of is which actual ip is being associated with the port - do you know if there's a surefire way of seeing that?
many thanks for your assistance 🙂
