speed drop again
redmikekite
Chat Champion
Message 19 of 19
Hi All
my internet speed has dropped again it was always around 39kbps then for the last year its been 35kbps and now today its 27.4 kbps into the router, I have turned the router off for 30 mins and its connected to the test socket also my pc is not wifi its connected directly to the router. I have done a line test and everything is coming back clear. I am using a third party router and have tried my talktalk router and its still the same. As i have said in previous posts this seems to happen 1 to 3 times per year. My fibre connection is via FTTC. Any help would be really appreciated
18 REPLIES 18
Message 1 of 19
You're Welcome 🙂
Message 2 of 19
Hi Karl
Just checked we are now getting 40 into the router and the download is a steady 36 it's the best it's been in a couple of years really appreciate your help
Many thanks
Mike
Message 3 of 19
No Problem 🙂
Message 4 of 19
Hi Karl
OK thanks I will check later
Mike
Message 5 of 19
The data in My Account will not be real time, so do check the sync speed when you get home.
Karl,
Message 6 of 19
Hi Karl when I login to my account it says the speed to my router is less than 26 which is my guarented speed
I will double check it when I get home looking at the graph on my account its been gradually decreasing the week or so
Mike
Message 7 of 19
Ok, sync hasrecently improved.
Message 8 of 19
Hi Karl
I can't at the moment as I'm at work I will try when I get home and let you know
Regards Mike
Message 9 of 19
can you test now please.
Message 10 of 19
Hi Karl
Just an update no change to the speed this morning I have tried a new filter just in case as well but no difference
Mike
Message 11 of 19
No Problem 🙂
Message 12 of 19
Hi Karl
OK I will leave it and see what happens
Mike
Message 13 of 19
OK, if you leave the router on, we can see if the line profile increases over the next couple of days.
Message 14 of 19
Hi Michelle connecting is OK now with the talk talk router it was loose ethernet cable from my desktop, speed into the router is still the same I will leave it connected and wait and see
Mike
redmikekite
Chat Champion
Message 15 of 19
Hi Michelle I have the talk talk router now connected but its constantly losing Internet connection not sure what to do next
Mike
Message 16 of 19
Ok thanks for confirming. We will re-check the connection stats again in the morning to see how they compare with the alternative router connected.
Message 17 of 19
Hi its already connected to the test socket and I tried the talk talk router yesterday and there is no difference I'm at work at the moment I will try it again later when I get home
Mike
Message 18 of 19
Good morning,
I'm sorry to hear this and I will take a look now. I've run a test on the line which is clear, however I can see that the sync speed has dropped. Is the router still connected to the test socket at the moment please? Is the voice service also ok with no noise on the line? Would it be possible to re-connect the alternative router again for a short period so we can re-check the connection stats?
