using DECT phone with eero
Rhiaff
Message 3 of 3
Hello, I have been advised that I can connect my DECT phone and retain landline number with the eero router and full fibre, is that correct?
Message 1 of 3
Thanks @Divsec  🙂
Divsec
Message 2 of 3
Hi @Rhiaff this should help
https://community.talktalk.co.uk/t5/Articles/Setting-up-your-eero/ta-p/2760450
You need to carry your phone number with you if you switch, it becomes difficult if it's an afterthought
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
